Hi, This is a similar post to @Biker2772's about slipping gears. I suppose all cases are different, so I'm posting my own thread and I'll paste below some detailed images. The gears Ultegra with this code embossed: "RD-6500 VIA". The bike, a Principia Rex, is 20 years old and I bought it recently. The gears were almost perfect when I received it, it just skipped a gear on the smaller cogs of the cassette when dropping down to lower gears from top gear. Took it to a shop for adjustment but it came back worse. Returned to the shop and it turned out even worse again. I took it to another shop where they suggested I should change the chain and cassette. This was done. They also suggested putting the rear derailleur into friction mode (on the shifter I suppose?) because the gears have too much "play" in them (i think that's what he said but i didn't speak to the mechanic). This also was done. I went for a ride this morning and the gears are much better but the occasions hiccup occurred while dropping down the gears. Too me, the rear derailleur seems pretty solid with no slack or movement when handled.
I hope someone can offer an opinion with these photos. Buying a new derailleur is out of the question for me because the prices are eye wateringly high here. But might it be the case that the gears can be serviced (where I wouldn't know) with a change of parts where necessary? The bike has bar end shifters but I'd like to put STI's on it in the future if the indexing/slipping problem can be fixed.
Front derailleur works perfectly.
Cheers,
Cheers,
