- Shrewsbury, Shropshire
As long as the derailleur is remounted correctly there shouldn't be any problem with chain clearance. Just remember that the mounting bolt should go through the drop out slot into the clamp plate. If the clamp plate is missing (which I suspect is likely given that way it's been fitted) perhaps consider updating your rear derailleur to one of these: http://www.halfords.com/webapp/wcs/..._productId_503761_langId_-1_categoryId_165694
Doesn't have to be from Halfords - just an example.
