Dave 123
- Cambridgeshire alps
When you say “intelligent life will wipe itself out” How intelligent is intelligent? Earthworm level?. Butterfly? Slow worm? blackbird? Mouse? Dog? Cat? Squirrel monkey?
A very few technologically advanced (not the same as intelligent) humans have developed the ability to wipe out just about all life on Earth, but the vast majority haven’t, couldn’t, and wouldn’t. Perhaps on other planets sanity has prevailed.
The warping of space time due to massive objects does not enable faster than light travel.
NASA on lensing and dark matter
https://science.nasa.gov/universe/how-gravity-warps-light/
Summary of recent theoretical research
https://physicsworld.com/a/spacecra...ld-travel-faster-than-light-claims-physicist/
The furthest objects detected are estimated over 13 billion light years away.
They are much further away than that due to the expansion of Space.
Around 46.5 billion light years.
Aa determined by red shift analysis of starlight that started its travel some 13.8 billion years ago.
Nothing can travel faster than light, at least with the current understanding of physics. The faster physical object travels the heavier it becomes, until it becomes infinitely heavy at the speed of light. It is not possible to provide infinite thrust via conventional means, making light speed travel impossible.
You need to set aide the conventional comcept of "travel", or distance, time and therefore velocity. Manipulating the structure of space-time would be circumventing those extreme distances insted of actually traveling them in full. Think of it as taking the lift - the conventional route might be walking round and taking the stairs which could be a journey of hundreds of feet, but the lift takes you to the same destination for a journey of 10 feet. Or in one possible scenrio the lift wohld remain stationary while the building itself moves up ormdkn around us. So using my theoretical suggestion we would be taking taking an extreme shortcut, possibly even at zero relative velocity by manipulating space around us as we remain in place, rather than actually travelling ourselves.
As aforementioned by my good self, we know the structure of space time can be affected (or manipulated if you will) by mass and gravity because we see it in nature - there are no physical laws being broken. However, humankind will likely never be able to manipulate it for ancillary reasons such as energy budget, etc (energy budget being my favourite objection, did some of the maths for that for my Masters - we'd have to likely harness the energy of galaxies worth of stars, which seems unlikely in the extreme.)
But just because we may never be able to do it doesn't mean physics won't permit it...because we can clearly see with a telescope that it does.
We are using different definitions of distance
https://explainingscience.org/2021/03/13/distances-in-cosmology/
Are we?
I thought the discussion was about the actual size of our observable universe ie the current distance to the furthest objects that we can see.
The comoving size of our observable universe has an actual diameter of around 93 billion light years. Hence 46.5 billion light years is the actual distance from Earth to those furthest objects; even though the light from those objects has taken 'only' 13.8 Billion years to arrive at Earth.
https://en.wikipedia.org/wiki/Observable_universe#:~:text=The comoving distance from Earth,8.8×1026 m).
Yes the original discussion was about the time light from distant civilisations would take to get to us.
The objects' distance, as set out in link you post can be described in this way (light travel distance) or by your preferred measure. They're not inconsistent, just different. Both are valid.
The actual distance is 93 Billion light years ie the size of our observable universe
Yet from your own link
The Universe is homogeneous and isotropic, so it has no edge. Thus there cannot be a maximum distance
we're just describing the same thing on different ways.
Or is it ...The Universe is homogeneous and isotropic,
