PhunkPilot
Renegade of Phunk!
- stubbington
Surely if you use clipless one side and flat pedal the other you'll just cycle round in circles due to the uneven spread of power from your colossal leg muscles?
Not on a single-tracked vehicle like a bicycle, duh!Surely if you use clipless one side and flat pedal the other you'll just cycle round in circles due to the uneven spread of power from your colossal leg muscles?
Which just makes me think - how about taking the pedals off, having a hole drilled in each ankle and getting spindles threaded at the crank end and just plain at the other end fitted to the bike? To put your foot on the ground you just move your leg away from the bike and the spindle comes out, to start up again you lift up your leg and move it so the spindle goes back through the hole.
Well I had to pop over to the other side of town this morning and I wore trainers and used a bike with flat pedals, it took me 30 minutes longer than if I'd not bothered going in the first place.
GrasB, henceforth to be known as ... KEO MAN!... it may have appeared that the 'serious' cyclist was really posting his unfunny comments in a fit of pique after his tale of defeating two cars, thanks to his 'Keo Power', went unheeded...
PotsySome might say that your arrival truly heralds an end to the humour
Reading your posts I hadn't realised it had started, Mr Mardy Pedals.
Symmetry is SO overrated, though.That's why you have to remember to swap which foot is clipped in every ride, or you'll end up deformed
That's it, have a dig at me for something Potsy told me to say!!!
You're Potsy's patsy?
