but wouldn't that make me fall off my bike?
Although you might break your ankle if you are clipped in at the time.You'll be fine. You have a helmet!
You may be onto something here. Take a piece of, (arguably) unnecessary equipment, use it in such a way as to increase the risk of accident or injury, and simply mitigate the effects by donning safety equipment. All you then need to do is to start an online discussion on the matter and the justification for the extra expense appears as if by magic.but wouldn't that make me fall off my bike?
By the way McB, I suspect you are sponsored by the purveyors of flat pedals, and are trying to steer us away from 20 quid wellgo PSD and 20 quid Lidl shoes towards the non-hyped and mis-marketed flat pedal:
http://www.hotlines-...x?ModelID=43495
£150 for a pair of pedals...
Did you see the blurb though?
"We analyzed everything that was on the market and started with a clean slate to completely re-invent the pedal."
They are very clever though because despite all the design changes they managed to disguise them to look like...well...er...a normal pedal!
i had my flat pedal moment on clipless m520 pedals. put on my trainers, cycled to the shop one mile away and back. am i accepted to an elite flat pedalists circle now?
Zizou's total spend was £390. Probably needs to add more for replacement cleats.£150 for a pair of pedals, are you insane man? you've got to be looking in the sub £20 region to find mine
You're missing the whole point, which is clearly one of ground clearance "the thinness of the pedals lowers your center of gravity for increased stability and better cornering, brings you closer to the axis of rotation for a more effective pedal stroke and increases your ground clearance so you are less likely to be obstructed by objects on the trail. ", 'cause 5mm higher and you'd get catapulted off the trail with every rock strike, wobble around unable to complete a whole rotation of the cranks, and fall over on corners. .Did you see the blurb though?
