Fixing a puncture or replacing inner tube when dirty
Status
Not open for further replies.
Sharky
Kent
M
Milena
My preference is for steel ones, with hooks for holding with the spokes. And you need three.
https://www.halfords.com/cycling/bi...lfords-steel-bike-tyre-levers-x-3-134163.html
What are hooks for holding with the spokes? What is that? It does not state on that listing that those levers have hooks for holding with the spokes?
Why steel over plastic or metal core plastic exterior?
Just buy a set of Pedro's levers and you'll need nothing else - they will even get tight tyres on. The hook is for keeping one lever in place whilst you use the other two. I only use two, or my thumbs. Most tyres will go on by hand. Some are pigs and need levers.
Amazon product ASIN B000N22G1QView: https://www.amazon.co.uk/Pedros-Pink-Tyre-Levers-Pair/dp/B000N22G1Q/ref=asc_df_B000N22G1Q/?tag=googshopuk-21&linkCode=df0&hvadid=310485825261&hvpos=&hvnetw=g&hvrand=8520492241122914401&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006912&hvtargid=pla-585697848227&th=1
Other colours available
gbb
Peterborough
UPDATE - Spoke to the LBS he said there was a puncture caused by a big ol thorn. He added that he took a photo of it.
So ermmm apparently that was it.... Wonder if any LBS's purposely insert a thorn or nail to make it seem like there was a puncture when there wasn't? Not saying he did that. Just something I thought of. It would be VERY easy to do that after all.
You're overthinking it. Trail and track riding (even on the roads) thorns and flint shards are a common problem so no surprise the LBS found one.
One important thing when you're learning to fix punctures, as the tyre is off, run your finger around the inside of the tyre itself, feel for thorns, spikes, shards etc. Nothing worse than fixing a puncture then it immediately deflates because you didnt take out the (unseen) offending thorn/glass/ shard. A fingertip is very good because its sensitive, but go gentle so's not to injure yourself
At the end of the day, you have several options that will help prevent punctures but not completely.
Buy better tyres.. puncture resist tyres have better protection but tend to be heavier
Buy some slime and use that. It does generally work but it adds weight
Plus tyre liners etc etc
You pays your money, its pros and cons with each option.
How's this for a thorn.
Alex321
South Wales
I shouldn't think so. You knew you had a puncture, why would they need to fake one?
A puncture is always caused by something - either by something that penetrates both the tyre and the tube (which may not remain in the tyre but often does), or by tyres run at too low a pressure compressing and crushing the tube against the rim (often called snakebite punctures because there will usually be two alongside each other), or occasionally as mentioned above, by movement inside the tyre causing wear from rubbing. The latter will not usually happen with just they tyre and tube.
Impressive.
And it was muddy and wet, so dirty hands. I think it killed the tube in memory. Didn't struggle to find the thorn though ! :laugh:
Status
