Brandane
The Costa Clyde rain magnet.
Late to this thread as only just seen it, but thought I would share my experience of BPE...
Have had prostate issues for many years, probably since about the age if 50 (now 61). Began with frequent urination. Had several DRE's over the years, which confirmed enlarged prostate but PSA was normal so I was told not to worry. About a year ago I was put on tamsulosin to try and help with flow. There followed an appointment at urology clinic for a routine follow up in April 2023. I thought things were improving so it was a bit of a shock when I failed the flow test quite badly. Then a scan of my bladder revealed 800ml of urine still in there AFTER I had supposedly emptied it. The nurse wouldn't let me leave the hospital without being catheterised to empty my bladder. 800ml duly delivered into a bowl.
I was put on Dutasteride to try and shrink the prostate, this is on-going so no idea if it is working, but I suspect not. The reason I suspect not is because I have to self catheterise every night before bed (single use disposable things which for me are preferable to the alternative of having a permanently fitted catheter). Using this method for about 7 months now I am still drawing between 600 and 800 ml every night. Nurse told me (in August) that it should be down to about 300ml by Christmas and that I would then be free of the catheter procedures. Obviously that didn't happen!
Next telephone consultation with urology nurse is next month, so I will find out the next step then. I did have a face to face appointment with the consultant in October, and was basically told that it might be my bladder muscle which has been over stretched and beyond repair. In that case a prostate op is not worth the risks attached as I would be left with my existing problems re "chronic urinary retention". So best get used to using the disposable catheters (which initially caused much grief with regular UTI's). I have to go for a urodynamics test (which sounds like more torture) in March, to ascertain whether or not my bladder muscle is the problem or not.
Such are the joys of being a male in his 60's 🙄.
Edit to add the positive side: Using a disposable catheter before bed every night means that you are actually emptying your bladder. Which has done away with the problem of getting up for a pee at least twice every night. I can now quite easily go to bed at 11pm and not have to visit the toilet until 8am.. Luxury!!
