rb58
Enigma
- Bexley, Kent
Mine is 101, and have two more 102+ mile rides to get it to 102 and 11 more 103+ mile rides to shift it to 103. Getting it to 104 is not going to be this year.
Absolutely. But if you are on Garmin Connect, you can only sort your rides in length order using @ianrauk suggested method, it won't consolidate a days ride - unless I misunderstood.I've always thought it was the number of miles in the day ridden as opposed to miles done in a single ride.
6 and 3/4 inches, on average, discounting nylon string-like abominations.calculating the length of a piece of string
But if you are on Garmin Connect, you can only sort your rides in length order using @ianrauk suggested method, it won't consolidate a days ride.
What we really need is a sort of Naismith rule for cycling, which would be a bit like calculating the length of a piece of string, but, if you've got the elevation data, it might be interesting to work out an ascent E number. So, for example, a number of Em 300 would mean that you've climbed 300 metres 300 times. Or E' 300 would mean 300 x 300 feet.
You need a unique method of determining height climbed. Which, given the vagaries of the granularity of height databases and the imprecision in the z-axis of GPS units (whether corrected by atmospheric pressure or not) is not going to happen.What we really need is a sort of Naismith rule for cycling, which would be a bit like calculating the length of a piece of string, but, if you've got the elevation data, it might be interesting to work out an ascent E number. So, for example, a number of Em 300 would mean that you've climbed 300 metres 300 times. Or E' 300 would mean 300 x 300 feet.
That goes without saying.You need a unique method of determining height climbed. Which, given the vagaries of the granularity of height databases and the imprecision in the z-axis of GPS units (whether corrected by atmospheric pressure or not) is not going to happen.
