Mine is 75. Assuming I get out on Sunday as planned, it will become 79.2
Surprised, thought it would be more then that.
I think I'm doing it right. Exported to Excel from MyCyclingLog. Sorted into large to small distance, first time the distance is less than the row number+1 (for the header).Surprised, thought it would be more then that.
Um, E numbers can't be fractions. That's kind of the point of them.Mine is 75. Assuming I get out on Sunday as planned, it will become 79.2
Picky. 79 thenUm, E numbers can't be fractions. That's kind of the point of them.
If we're being picky that's not a fraction, it's a decimal.Picky. 79 then
Forgive me for challenging you - but I really don't see why that's the case. Row #101 will just be your 100th longest ride. If it's more than 100 miles, then your E-number is 100 or more. If it's not, then it's 99 or less. You need to look at all the rows to determine your E-number - if I had a brain at this time of the night and a spreadsheet in front of me I could write a formula for it.In activities. At the bottom right is an 'export to csv' button.
So export all your rides. Then import them into an excel file.
In the distance column, sort so that your longest ride is at the top and descending down.
Look at ride # 101 (Row 1 will have the value descriptions), that should be your Eddington number.
You said you Eddington number will be 100. In that case. Row # 101 should be 100miles+
Hope that makes sense.
Unless, that is, I've missed something about the structure of the exported data.
You will also need to take into account any column headings as well. So, (just for anyone else following this) of you have put something like date and distance at the top of the column this will need to be accounted for. This may have already been mentioned. I'm not sure. I just use the spreadsheet I wrote and record the total distance i for that day in the table and it gives me the answer.Nope, you are right.
My Eddington number is 104 (I did have 105, as I took the 100 x 105 miles rides not 104 rides of 104+ miles as it should be
If it was 99 then you would have to do 99 x 99 miles rides, 100, 100x100 etc etc
Below is a screen grab from excel, removing the top row. So my Enumber is 104, with 2 more 105's to reach that number
Maths was never my favourite subject
I haven't tried it as a formula in a spreadsheet but that's the way I understand it. You could always add a number count row starting one down, or two if there's a distance heading, taking care not to sort it with the mileage column.I think and this needs checking the formula for a spreadsheet with headings and sorted longest ride first is going to be:
EN=(row number>mileage)-1
