knocksofbeggarmen
Fair's fair. I've only started and you have a big lead.
How big is Copenhagen? 88.25 km²
How big is Amsterdam? 219 km²
How big is London? 1,572 km²
Population of Copenhagen? 559,440 (2013)
Population of Amsterdam? 779,808 (2011)
Population of London? 8.174 million (2011)
(Source: Typing "how big is nnnn?" and "Population of nnnn?" into Google)
Instead of just trotting out clichéd responses about the wonders of the Netherlands and Denmark can we have a UK solution for UK requirements please. A 21st C response to a 21st C challenge? It may be me but it looks like the challenge for London in 2013 may be an order of magnitude, or two, larger than faced by our continental cousins in the last quarter of the 20th C.
so much time, so little to say......control 'I'You correctly identify that Busses and cycles massively hinder each other: .
Putting him in italics? Ruthless!so much time, so little to say......control 'I'
Thing is, I don't agree with you, and someone who actually lives there doesn't either.No it's not really... I know as I have cycled extensively in both countries.
Ah - David Hembrow... someone who is known to have a somewhat tenuous link with reality at times and to have his own axes to grind. I suggest you find something a little more robust to support your assertion if you want to retain what little credibility you have left....
"You mention Belgium, and it makes an interesting comparison. Ride across the border from NL and the low quality of the cycling infrastructure is immediately apparent. You also stop seeing so many cyclists. This happens even just over the border in the rather flat bit just south of Eindhoven, which is less hilly than Limburg. I'd call that correlation." http://www.aviewfromthecyclepath.com/2009/10/effect-of-hills-on-cycling.html
My point was that you have to start somewhere. seeing as you are so good at statistics, maybe you can tell me how many regular cyclists London has compared to Copenhagen.
Steve
quite. The rules governing cycling in Belgium seem to me to be designed to stop groups of people going out for a fun ride.Correlation is not causation.
May I just mention that I've driven south of Eindhoven then driven across the border of both Belgium and France this evening and barely seen a cyclist since leaving Boxmeer?"You mention Belgium, and it makes an interesting comparison. Ride across the border from NL and the low quality of the cycling infrastructure is immediately apparent. You also stop seeing so many cyclists. This happens even just over the border in the rather flat bit just south of Eindhoven, which is less hilly than Limburg. I'd call that correlation." http://www.aviewfromthecyclepath.com/2009/10/effect-of-hills-on-cycling.html
