jimboalee said:OK,
18.75 mph is one fifth of a Horsepower on a 'straight arm sports' bike.
So FFFF, you are less than one horses leg
75 cadence is 'average' for a broad range of cyclists when climbing.
Ant said:Very interesting stuff I must say.
It's inspired me to try and work out the gearing on my new bike using the 'Sheldon Brown' calculator, but I'm having a bit of an issue with wheel size.
They're Rodi Airline Evo 700c with 31mm rims
Not sure what that translates to on the calculator. Do I select 700X32 as the closest?
I've never really put much thought in to wheel size before![]()
Fab Foodie said:I assume you mean the tyre size is 700x31c, so calculating for a 700x32 is more than accurate (all tyres of a particular size vary plus or minus a mm or so anyway).
yello said:FF, I think tyred's explanation above is useful for getting a handle on jimbo's methodology. Your questions to jimbo are arguably in a different language. You're perhaps asking him to answer your questions in your language.
Anyone that's ever done any kind of translation work will tell you it's not always possible to provide an exact, or even adequate translation. In the absence of learning the mother-tongue (as it were), you'll just have to appreciate the beauty and take on trust!![]()
Crackle said:Except, I used to ride a regular mile and a half 10% and climbed it in a 37" gear at 55rpm, so it's close but not spot on. Unless of course the sign saying 10% was wrong .
jimboalee said:(The end of a 1m spirit level should be 10cm off the tarmac.)
jimboalee said:It has amazed me just how argumentative people are.
