Disk brakes
martint235
Dog on a bike
Welling
So I'm being thick. Fitted new pads but when I put the wheel back in the disk is too far to the outside of the bike and I'm struggling to stop it rubbing. I have the QR lever on the disk side of the wheel. Because of the mudguard I can't turn the QR to tighten or loosen on the bike, I can only open and close it.
So I'm having a mental block, to effectively move the disk towards the inside of the fork, do I loosen the QR and tighten the other side before fitting or vice versa
Kajjal
Wheely World
You can just loosen the calliper bolts, realign by eye and tighten back up carefully. If hydraulic with the pads in very gently push the pads apart with a largish flat screw driver and if a piston is stuck or out of position this will sort it but be gentle.
Loch side.
Both pads float and by fiddling with the one more than the other you can change the offset of the gap. Usually this self-corrects but if the pistons are sticky, this doesn't happen. Look up how to clean and lubricate them and then try again.
martint235
martint235
Dog on a bike
Welling
No, the wheel should be seated with its axle in the dropouts evenly.
What brake is it?
They are BB7s.
Both calipers are fully loosened yet when I put the wheel in, the disk is rubbing against the outer pad.
When I get home, I will draw a pretty picture on my snazzy iPad with Pencil to show what I mean (I've got to do something to make it worth the money)
martint235
martint235
Dog on a bike
Welling
Right, in that case
Re tighten the alignment bolts with brake held on
Ok thanks all. Will give that a go when I get home.
I'm still going to draw a picture though.
Jody
Stubborn git
I find disc brakes easier to align first time by eye, checking daylight through both pads.
martint235
martint235
Dog on a bike
Welling
So I promised a sketch. Done in a kind of crayon as requested by @User
So if you imagine the QR is left and turned anti clockwise and the nut thingy at the right is turned clockwise, doesn't this shift the axle right relative to how it fits in the dropouts
Edit: yes I know the right hand arrow is also going anti clockwise but I couldn't be a***do to draw it again
