Nope. I've been using discs on my mountain bike for, I reckon, 15 years or longer and never had a problem despite numerous offs and mishaps. Even if a disc did get bent, as somebody wrote above, they are easily bent back. The biggest problem with discs is that the bolts that mount them to the hub are usually small and made from steel, meaning they can get siezed in the alloy hub and then the socket gets rounded out making them very tricky to remove.
There are very good reasons why Torx is far superior to both internal and external hex
Magura use Torx bolts which makes on the fly fettling harder because you have to carry a Torx driver set in addition to allen keys.
Not to mention the occasional Magura installation on which the fixings have been wrecked because someone tried to use allen keys.
Well you hardly need a set of torx drivers for one size of bolt, although I do agree a mixture of fastener styles is a bit of a nuisance. Change the rest for Torx perhaps?
I don't think it's been a secret, although it did have a patent I think.Yes, but are they a secret?
More, er, Torx is about the strength of it.
Just being pedantic,they will be screws in the hub, not bolts.
There is nothing wrong with decent rim brakes in the dry - I can easily lock the wheels when operating my Campag Chorus brakes with just one finger on each lever. They actually work pretty well in the wet too, but do require more than a one finger effort per lever. The main problem for me is the wear issue.It's an interesting thread this. The consensus from respondents who have used both is that discs are far superior, BUT, if a disc brake is defined as a disc pinched between two pads, then we ALL have disc brakes, some using a 27 inch disc, some using an 8 inch one. Now, in general, a bigger disc generates more leverage, so what's going on? Is it simply steel v ally? Do rims limit the power we can use because they are not solid? Is it just that there has been insufficient development in caliper brakes?
Has anyone tried the new Shimao callipers?
You've hit the nail on the head. This sums it up nicely.There is nothing wrong with decent rim brakes in the dry - I can easily lock the wheels when operating my Campag Chorus brakes with just one finger on each lever. They actually work pretty well in the wet too, but do require more than a one finger effort per lever. The main problem for me is the wear issue.
