Wobblers
Euthermic
- Minkowski Space
While it is a fair point that the maximum amount of braking you can do is limited to the point at which you'll end up going over the handlebars (or grip, if the road surface's atrocious), meaning that it doesn't matter whether your brakes are rim or disc, this misses a few important things. The first is that in wet conditions, rim brakes need to clean the braking surface of water before they bite. That half second pause whilst your brakes think about working is a very long time when someone's just pulled out in front of you. Don't ask me how I know this! Worse, in heavy rain or spray, or when there is a lot of surface water, the rims never dry out sufficiently to get effective braking. I've been in that position and it is not pleasant. Discs do not suffer from either problem. I've just bought myself a CX bike with disc brakes for the commute because I want predictable braking under all conditions. Why would you not?
