Often though we need to make decisions and take part in debates where we cannot have a complete "personal knowledge" of the subject, and need to rely on the experience and research of others.
In the modern age this varies from the "scientific paper" to an article in "Hello" or "Chat" magazines
There needs to be some method of deciding how valid that information is.
Without this it simply degenerates into a "my experience is ... so you must follow my decision"
We have to recognise that this is the case, especially when conflicting information is presented.
In a debate like the helmet debate, we have information that is presented and is often erroneous, deliberately misleading and misinterpreted - unless there is a deeper understanding this can be missed.
Is personal experience on its own good enough as a justification for a decision at this level?
The original table is an example, and altough you may not realise this - look again at the first posts and see how the data has been questioned, shortcomings raised and discussed as opposed to simply slapping polystyrene on our heads in blind obedience
Presented evidence and whether it should be accepted or refuted depends on the expert, the research performed and how it was performed.
What was the bias, was the data collected properly and verified. Does it stand up to peer review. Are the results limited in their application or are they transferable to other similar or disparate groups.
Critical analysis of the evidence and form an informed conclusion of that particular instance is the answer to deciding whether that information is valid.
You cannot simply accept the information as "beyond doubt", or if you do then do you need to be consistent
For instance, an example I have used elsewhere:
Lets accept that we should listen to the College of Emergency Medicine and listen to their advice when they promote helmets. This is because they are experts in A&E Medicine and know what they are talking about.
If we accept this without any critical appraisal of their evidence then it follows that as the "Thudguard" is promoted by the same organisation,we should also accept the recommendation without question.
You cannot simply advocate accepting one and not the other without justifyingthat in a measured and reasonable way
