Cyclists who use strobe lights are...
downfader
extimus uero philosophus
'ampsheeeer
I may be getting the wrong end of the stick here, but most modern led lamps strobe at something like 16-25Hz , it gives the illusion of a constant bright output but reduces the duty period of the led components saving battery life and extending the life of the led.
I think the waveform is the source for those hertz not the oscillation/amplitude of the on-off? I could be wrong.
GrumpyGregry
Here for rides.
as a driver i have NEVER not been able to judge the distance or speed of a bike bcoz they had a front or rear flashing light. I think this is a bollox excuse from drivers who need an eye test. (that said, I'm yet to see a strobe light so I'll keep you posted)
I used to claim this until quiet recently. Learning otherwise was a sobering experience.
gaz
Cycle Camera TV
South Croydon
I run a 350 lumen rear light on the back of my low racer & it's not objectionable in the least, intact I probably need to drive it a little harder because at close range it can look a bit dim! The reason? It has a surface area of 122.71cm^2, a typical rear back light will have a surface area of 2.54mm^2. If we do the maths that gives my rear light 2.85 lumen 1cm^2 but if you take a 75lumen 1 LED rear you're looking at 30 lumen per 1cm^2! That's car rear HID/brake light range.
That intensity of the less bright light means your eye tones down so that the point source isn't overloading its sensing abilities. That makes it very hard to see anything else. However my brighter rear light simply doesn't get that intense, it actually seems to get dimmer the closer you are to it!
The problem with making something that big is that on a conventional bike it's kind of hard to mount a 13.25cm diameter light.
350lumen rear light? What is it :S
classic33
Leg End Member
I was about to say that the Epilepsy thing is more complex
It is about a whole range of factors - the only "recorded" incident was where the person was fettling and it may be the intensity at close range rather than the flashing rate that was the cause
I was a welder at one time, and it never triggerered a seizure.
When we get passed the blinkered view that flashing lights can trigger a siezure then we can knock this myth on it head, once and for all.
classic33
Leg End Member
I caught this in December. Ridiculously focussed beam, illegal flash frequency and could cause epileptic reactions in those affected. Wish I'd said something.
As could all the headlights coming the over way, one after the other, using that reasoning. Theres the same strobe effect there and the lights are brighter.
See
http://www.epilepsysociety.org.uk/photosensitive-epilepsy & https://www.epilepsy.org.uk/info/photosensitive-epilepsy/triggers
I mean can we get rid of these, using the same argument.
The hardest part with living with the bloody thing is peoples preconceptions of the condition. And what may cause the bloody seizure in the first place!
We are not blinking stupid about a condition we suffer from.
Black Country Ste
West Midlands
Fair enough. But you don't disagree that lights like that are a dangerous nuisance?
classic33
Leg End Member
Health & Safety gone mad is a better way of describing it.
Unless you're well lit up, lights that can be seen for miles have become a basic for anyone buying new lights. And the sad fact is people fall for it.
I have a horse riders vest, LED's built into it. Does it get me noticed at night? I don't think it has once been noticed whilst actually moving on the bike. At a set of lights with a car in the next lane, yes.
I fitted a half million candle power light to the bike when working in Leeds, using it on the unlit sections of the A58, I still got the excuse that my front light wasn't bright enough when I got knocked off by a British Gas van driver. Police disagreed, when one of them went to check it.
Difficult to measure the flashing rate, but see above, it is very unlikely to cause an epileptic fit.
According to the British Epilepsy Association there are no recorded cases where a bicycle light has triggered an epileptic fit
Out of interest, how do you measure a lights flash speed?
Tried a couple apps online but they are making a strobe, not measuring.
Thinking something using the camera fucntion on my phone?
