Coronavirus outbreak
......as the minglers swan about at will, possibly infecting people?
Nothing's stopping you swanning about at will either, you just choose not to then judge people who think differently to you but are doing nothing that isn't allowed?
Julia9054
Knaresborough
Well, this is where the non minglers need to keep their precautions in place isn't it?
Masks, distancing, avoiding indoor areas etc.
Or keep regulations in place for situations where mingling is difficult to avoid - public transport, supermarkets etc
And remove then from situations it is easy to avoid - pubs, nightclubs, restaurants etc
Ajax Bay
East Devon
Au contraire, @shep, old chap; cases will at least drop away (if not "go away") before the summer is over (autumn equinox). All the modelling says so.
https://assets.publishing.service.g...and_Sensitivity_Step_4.2__6_July_2021__1_.pdf (Published 6 Jul and considered by SAGE before they advised the Government on no earlier than 19 Jul (or not).)
If the population takes a fair time to adopt behaviours similar to pre-pandemic the modelling suggests that that will result in a lower peak to this wave, but interestingly, and counter-intuitively, that it will also result in a fourth wave in the winter (which would be excellent to avoid - suspect the epidemiologists would agree: rock and hard place).
The red/blue/green curves below (VE = vaccine effectiveness; default = best (as opposed to optimistic or cautious) estimate).
Note: The dashed black line shows the mean trajectory for the worst case assumption of immediate return to pre-
COVID mixing on 19 Jul.
Edit: Note 2: The areas under the purple line and the red line are similar (<20% different) so the number of cases/admissions/deaths (estimate/modelled) will be similar, but the red trajectory would result in far less stress on the NHS as its peaks are far lower (but the corollary is that the domestic threat from COVID-19 endures through to Easter).
" Just 'cos you can don't mean you should".
In YOUR opinion.
Au contraire, Shep, old chap; cases will at least drop away (if not "go away") before the summer is over (autumn equinox). All the modelling says so.
Even better then, just need to convince these lot!
Ajax Bay
East Devon
We have passed a significant milestone that didn't get reported:
More people got immunity via a nasal rather than an intramuscular route on 10 July, and this continues.
[Assumption made (drawing on ONS antibody surveys for factor) that of those infected, only half (actually get a) test positive.]
The low rates of vaccination these last few weeks is remarkably unreported.
Unkraut
Master of the Inane Comment
Germany
I think we all know it's not going away anytime soon so at what point in time or at what level of vaccination or any other measurable stage do people think restrictions should be lifted?
Just curious like?
I think that is a fair question. My answer would be you lift restrictions when you can be reasonably certain that an increase in infections will not overload the healthcare system. Whilst it is true that in countries with highish vaccination rates the most vulnerable are now protected against the worst you also have to take into account that some younger people will die and that some will develop long-term complications that might not have occurred if you had waited until a higher rate of vaccination had been achieved.
A reasonable compromise to me would be to ease restrictions on personal freedom e.g. to do and watch sport, but retain the hygiene rules of masks and distancing where people get close together indoors. These latter are hardly a deprivation of liberty and can be very effective in dampening down the rate of infection whilst vaccination continues.
It would also seem wise to have a published backup plan reintroducing lockdown measures as appropriate to a local area to be implemented if the rate of infection coupled with strain on the NHS reaches a critical point.
