Dogtrousers
Lefty tighty. Get it righty.
Not really so, at least not in my case. I test before visiting my sister, who is vulnerable, just in case.Most of us have only ever tested if showing symptoms.
Yes to the bold bit because new variants can only establish by being more contagious than existing strains. Simple maths.
Not sure about the last bit. Alpha & Delta were both more virulent (lethal) than the Wuhan strain, so it's quite possible a future variant could be even worse.
What if you measure resting HR and HRV every single day. Let’s say you exercise every day or every other day and that includes heart rate and power data on the bike. Let’s include exercise that pushes you up to 90% or more of your max heart rate. You have a good understanding of your RPE and how that ties to your heart rate response and power output.
I would posit that you can’t have Covid-19 without it showing up in any of your daily data especially if you have a long and well established baseline.
Because you have absolutely zero symptoms or indication that anything is off, despite the long history of data from before and leading all the way through the pandemic. You haven’t been ill once , during the whole period.
Thats how you know it’s not a cold or flu because you’ve had nothing even close to those symptoms either, not a hint of it. You haven’t been ill once.
As I'm sure you're aware, this is incredibly unlikely and improbable. You appear to have a penchant for bickering and hypothesising, go outside, it's a nice day.
How do you know you haven't had it if you've never tested for it?![]()
probably cause i have never had any symptoms listed within the government recommendations to be tested for…..![]()
No it’s not, it describes my situation. It’s entirely probable because it’s true, and this from n=1. There will be plenty of other examples out there. There’s nothing hypothetical about it. We haven’t all been falling ill these past 2.5 years.
edit - well it’s all true but I’ve also been testing reasonably regularly since kits became available. All tests negative.
What if you were asymptomatic, like up to ~40% of people who've caught it?
You only test if you have symptoms…..and as i dont visit anyone, i work from home, i get my shopping delivered, then as per WELSH government guidelines, i have no need to take a test.
i hope that clears up, the same question you asked for a second time.
Wasn't the long term projection that the variants will be increasingly contagious but less lethal?
Only asked you once, will get you a calculator for Christmas![]()
I don't think there's any way to tell how the variants will go.
That's interesting. We had to test everyone at least every 2-3 days regardless of symptoms, when numbers were very high we had to test unvaccinated people every day. I'm not sure about the science with that last one to be honest; no-one ever explained why an unvaccinated person could be more likely to be an asymptomatic carrier, but there we go.
