Kevin Airey
Right where to start with an answer...
You really need that side to side movement, been 100% locked in without any movement would likely damage most people's knees and ligaments. The movement gives some flex for the pedal stroke as none of us have a perfect action, you should be able to feel a central point between the left and right movement, this should be your foots natural neutral position.
If you feel on your toes it may be that you are just not used to the correct position, or indeed you may be too far back. I had a bike fit recently and the recommendation is that the pedal axle passes midway between you big toes knuckle and you little toe knuckle.
My feet were marked up and then inserted into the shoes, then with the tongue of the shoe out they mark the outside of the shoe, so you can then see the correct position.
If you ever get a chance get a bike fit they will also set up your shoes, mine have wedges to help my knee action and it has made a huge difference for me....
