Cycling2Live
Member
- Richmond, VA USA
Today's ride reminded me that the same question pops up when riding into a head wind
Read an article that says riding on the hoods with the arms bent at 90 degrees is more aero than on the drops , my default positionToday's ride reminded me that the same question pops up when riding into a head wind
http://www.bikeradar.com/road/news/...faster-instantly-without-riding-harder-42744/
Surely bending the arms when in the drops would be the logical next step on again? Comparing a straight arm in the drops to a bent arm on the hoods is hardly fair?
I do agree that this/your position choice is very good mind you, and often choose that option too.
Chris Froome has the right idea staring at the stem it seems...except that he ought to look up a tad more in order to reduce his crash ratio...![]()
That might be more aero, but then again it is unlikely since your elbows will end up fouling your knees and hence you would have to spread them out wider than your legs.
Also by the time you start making your forearms horizontal while in the drops, your hip angle will be rather acute, hence likely to be limiting power output to a degree that offsets the aerodynamic gain anyway.
There isn't the need to get the elbows horizontal when in the drops in order to get the aero advantage though, as the lower hand position is already bringing your back closer to the position it would be with horizontal arms in the hoods position. Its marginal anyway.
I also tend to tuck with my pedals level when descending the steeper hills where you would spin out if pedalling. This creates less drag also. Obviously, I would pedal if less steep as enjoy powering downhills.
The main features of the crouching hoods position are, lower overall height whilst maintaining a reasonable hip angle, narrower arm/elbow position and level forearms. It is about shape as well as how low you go. So whilst you might get your back in the same position, your arms will be in a completely different orientation.
You appear to be assuming a flat back is more aero, this is not correct. Width and shape play a huge part in determining a riders drag. Probably more so than how low or flat you can go!
Also the presumption that it is marginal is a funny one... especially since the data itself suggests a reduction in CdA for the test subject of 0.0306, which is massive! It is over 30W, nearly a minute in a 10 mile time trial.
Unless I missed it, the quote was
The outcome showed that gripping the brake hoods with horizontal forearms produced the smallest frontal area and equated to a power saving of 13.4 percent at 45km/h compared with sitting up with hands on the hoods.
Nothing said about hands on drops
Also, I don't thing that riding with your head bent down is a position I would use. I like to see what's in front of me.
Hi all,
I keep seeing blogs, articles, posts, etc. that basically say that while climbing you should try to maintain a cadence of 90 - what I never see is an explanation of why 90 is such a significant number for cadence while climbing.
In our one-rider study, CdA dropped from an average of 0.3473 when riding in the drops (position 2 above) to an average of .3167 when gripping the hoods with horizontal forearms (position 3 above).
I am wondering about control of the bike in that position? I mean, you're appearing to be in a position closer to what is used in a time trial with handlebars that aren't really designed with that position in mind? Be gentle, remember I'm a noob about a lot of this so I could be 100% wrong about the direction I'm thinking here...
