I have a procycle chainset thats done over 8,000 miles and 7,000 on a Spa touring crank mine have been on a Viking Torino from 2008 though 14,000 of those miles are in the last 2 years, as its a triple its not been a priority to change it, I will be putting some 105 kit on today as my right Sora 3400 shifter failed at the weekend, and fed up getting kit off ebay that fails, a pair of 105 shifters went last night for £99+5pp I got mine from Ribble for an effective price of £117 and the FD about the same price as the one on ebay £17 its 10sp not the new 11sp, but the extra 12th gear wont really benifit me overall really as I have a 52x13 setup an 18th would have been better or something in the 20's as a 9sp it was 52/42/30 though I did change the 42 to a 40 sometimes 13/14/15/16/17/19/21/24/28 the 105 will be much the same but with 12 & 27 so not much of a change really in range a couple of inch and no change in the middle ratios.@Nigelnaturist, the sram PG850 cassettes are held with 2mm allen bolt so it's easy to make different ratio cassettes up (which I also use on my other road bike). the standard tdf procycle 42/52 chainset is only fit for the skip/sorry ebay pressed steel rings in grey primer yuk and the chain line was horrendous.
I'm happy with the tdf with the triple conversion, it's a totally a different bike to ride now, I'll run it as it is now for the coming winter.
This is the biggest problem with compacts as they come as standard, doubles are great for those who race as weight is an issue, if I had a compact like you I would be spinning at either end of the cassettee (well towards the end) my avg gear is 61-62" which on my bike is a 40x17 (well it was before i changed the middle ring at the weekend) which would give me a pretty straight chain line, for most riding I could have stayed on the 40th but did run out of length on slight declines, I guess the 12th on the new set will help there, however I could also spin on the lower rear cogs and the 52th, the 30x12 it was possible to ride up to say 15mph @90rpm, so having a close grouped cassette all three rings on the front can utilised effectively and better cadence control, for almost all my riding I could get away with a 52/38 and a 13-32 (13/14/15/1617/19/21/24/28/32) with pretty good ratios, the 30th helps on those steeper hills.I am just changing my compact on my vanquish to a 50/ 36 as i hardly ever use the 34 ring as i find the jump to big and end up spinning away till i slow down enough for the 34 ring to engage.
The vanquish has a 12-25 and the boardman has an 11-28 both of which i plan to run a 50/36 compact , i like the extra tooth either end on the boardman as it tends to be used more for training rides ( when time allows which is not very often atm kids etc ) where i need the extra both ends dependant on terrain and how much hammer i can put down on any day .The Vanquish is mainly a commuter and for the routes and weight i ride the gearing is ample .This is the biggest problem with compacts as they come as standard, doubles are great for those who race as weight is an issue, if I had a compact like you I would be spinning at either end of the cassettee (well towards the end) my avg gear is 61-62" which on my bike is a 40x17 (well it was before i changed the middle ring at the weekend) which would give me a pretty straight chain line, for most riding I could have stayed on the 40th but did run out of length on slight declines, I guess the 12th on the new set will help there, however I could also spin on the lower rear cogs and the 52th, the 30x12 it was possible to ride up to say 15mph @90rpm, so having a close grouped cassette all three rings on the front can utilised effectively and better cadence control, for almost all my riding I could get away with a 52/38 and a 13-32 (13/14/15/1617/19/21/24/28/32) with pretty good ratios, the 30th helps on those steeper hills.
