What pads are the best for carbon rims?
does anyone have experience with this shop...
http://www.planet-x-bikes.co.uk/i/q/WPPX52CCL/planet_x_52mm_carbon_clincher_wheelset
What about Planet x ones there are a few on the £4/500 mark and i think the reviews are not too bad but id rather hear it from owners
I have some 60mm and they're okay mate - with aluminium braking surface. I have to say that I only tend to use the rear and if I could have a choice again I'd go for a 46mm or less...60mm is a lot of section depending on what you use them for...?
Uphill they weigh the same as my aluminium Ksyrium Elites so the theory goes uphill, if you're going carbon then go for much less section because it weighs less than more section. For TT and flat riding they're faster for sure but they can be a hindrance on a descent, especially with a crosswind.
If I buy carbon deep sections again they will be tubulars and the reason for this is simple - the carbon clinchers are great for all round-use but these wheels don't necessarily add much to all round use if that makes sense having the advantages and disadvantages I list above which are specific. I would want them for competition and so tubulars every time make sense given they are lighter and faster. Saying this, they (tubulars) are not ideal for everyday use due to the hassle involved if you do get a puncture but when you're racing if you get a puncture it's game over anyway, so why not use the faster option.
Think about what you want them for but I would say if you want them just for general riding don't go as deep as 60mm - 38 or 46mm instead because they'll be more versatile.
Hi MR,
I am going to use the aero wheels for TT's and Triathlons only. So I supposed I would have to choose some with alu rims so that I can use both my training and racing wheels without effecting the brake pads.
My thinking behind Clincher was that if I had a puncture I know it would effect my times but I would still complete it after fixing the puncture. And dont have to go through the palava of gluing and taking the wheel apart.
But you make a valid point that if the Clincher is good for all rounder and Tubs for racing then that changes the perspective a bit. And tubs are a little cheaper as more readily available.
How would you handle a puncture on a Tub during a race?
How often would you need to buy a new tyre?
Thanks
I'm not the ideal person to ask about tubs per se but in regards to a race, it would be game over the same as it would be if you had a clincher on. However quick you are at replacing a tube on a clincher or repairing a tub, you won't 'get back on' so the race is effectively over for you if that makes sense.
Thanks Vamp and Fossyant, makes perfect sense , tubs it will be then :-)
Also, you can tape the tub on rather than glue if you want, it is quicker and less messy, but not suitable for all uses! I use tape for time trialling.
