In days of old it was common for tradesmen to,service their car, keep the old oil, and then use it to service the van.
You pass it down the line to anything you have that burns oil.
The car has air suspension on the back to give self-levelling headlights.
- I decided to start with the simple stuff like fuses, of which there are three, and the pump relay. Two of the fuses are easy to get at being in the front and rear fuse boxes but the third is a nightmare as you have to remove and disassemble the front pre-fuse box. Who knew there was a pre-fuse box before the fuse box? WHY?
I had a really weird experience today. Driving to the local garden centre I had a message "car rising up - please wait" on the dash, followed by "malfunction". Odd, I thought, but the car felt okay so I carried on but by the time I reached the garden centre (about 1/4 mile) the rear of the car was right down on the bump stopsThe car has air suspension on the back to give self-levelling headlights.
Once I'd finished shopping I restarted the car and (fingers crossed) hoped it would pump itself back up but no joy and I couldn't hear the air pump so I took a very slow drive back home, avoiding as many potholes as I could. After a bit of research on t'Internet and in the factory workshop manual - don't ask where that came from- I decided to start with the simple stuff like fuses, of which there are three, and the pump relay. Two of the fuses are easy to get at being in the front and rear fuse boxes but the third is a nightmare as you have to remove and disassemble the front pre-fuse box. Who knew there was a pre-fuse box before the fuse box? WHY?
Before I undertook that job I jacked the back of the car up and connected my multi-meter to the level sensor mounted on top of the differential. Good job I've got a low profile jack 'cos with the suspension right down there's not a lot of room under there. Anyway, that checked out okay. Then I made sure the pump relay was working which showed me that it wasn't getting any power ... bummer, that means I have to get into the pre-fuse box. This is truly a daunting task; not only is it awkward to get at but it has about a dozen electrical connections, some multi-pin sockets and others bolted. First thing to do is remove the battery to get more access, undo the single not that holds the box in place and then systematically undo the various cables and wires starting on the top before moving on to the the ones on the sides. The box can then be lifted out. Not only why does this box exist but why is the fuse I'm interested in the most awkward one to get at?
Fortunately (?) the fuse is okay and I can put the thing back together again making sure everything goes back in the same place it came out of - lots of mobile phone pictures taken ready for this bit. Why did I say fortunately? Well, Mercedes don't sell these fuses and you have to buy a complete pre-fuse box at some (undoubtedly) astronomical price. So, I get it all back together and the battery reconnected and fire it up to make sure everything is as it should be ... and the rear suspension pumps up
I've got no idea which bit of what I did resolved the problem but I suspect it might have been the act of disconnecting and subsequently reconnecting the battery that reset the system. My Carsoft diagnostic tool didn't show any fault codes, which is a bit disappointing. Fingers crossed this was a one-off
Apologies for the length of the missive.
Mercedes can be awkward to basic code scanners. Even top of the range still have difficulty with German veh
I changed the headlamp bulbs (remember those!) in our little Škoda Citigo this morning, the standard lights on dipped are so bad they are verging on being quite dangerous, hopefully these will improve the situation, I’ll try them out later this evening.
Easy job on the Citigo, the engine is so tiny there is plenty of room.
Can you post your findings please Gunk. I've been looking at those, H7 though as the dipped beam on my Civic is terrible. Just don't want to do it if they're a waste of time as changing the dipped beam bulbs is horrendous on it. One handed cramped access, get it wrong and the retaining clip comes off, the bumper has to come off.I changed the headlamp bulbs (remember those!) in our little Škoda Citigo this morning, the standard lights on dipped are so bad they are verging on being quite dangerous, hopefully these will improve the situation, I’ll try them out later this evening.
