rockyroller
- 20 miles northwest of Boston, MA
A decent breaker bar would have made that job easier.
thank you, yes!
& the torque wrench
Monday 18th
Joanne got home this evening & told me there’s a strange noise from the back of her Q3
I had a roll under with a torch, nothing immediately apparent, so had a drive
There was no real noises, but a roundabout created a ‘scrape/clunkm’
an in-dept look, once home, revealed a cracked rear anti-roll bar!
Story of lack of checks and maintenance
My mates daughter, said the oil light came on . He checked it the oil level. It required 3 litres to bring it back into the middle of the dip stickIt only has a 4 litre sump. He then told me the oil cap is milky too.
So likely blown head gasket and some bottom end ,rod, crankshaft bearings have been cooked. She wants a newer car, but hers is now pretty much worthless, due to repair costs.
Doh
So likely blown head gasket…
Monday 18th
Zafira had that problem wife cooked the bottom end bearings.
Probably not - in the cold weather you often get a bit of emulsion in oil caps and around dipsticks, especially if the car does short journeys. The cooler extremities of the engine can be a place where water condenses and then mixes with the oil to form the ‘mayo’. Some water in oil is inevitable because of how engines work - obviously lots of water is a problem that needs investigating.
