Deleted member 26715
Like a silly person I stripped down a Rover K series VVC head, now I can't find good instructions on how to put it back together to get the cams to line up properly
We have a maintenance engineer here who is very proficient on cars and does a lot of work from home, there's not much that phases him. He send the heads out when he does top ends, leaking head gaskets etc. He reckons its not excessively costly, someone else does the donkey work and he knows it will be 100% when it gets back. No brainer he reckons.I took one look at the FZR head and promptly sent it to a specialist engineer to redo the valves and set the clearances. I could have done it, but would have been such a ball ache I reckon the expense was justified.
And the same guy i mentioned in the post above stripped a Beemer head then realised he couldnt work out how it went back (the one time he bit off more than he could chew by his own admission), VVT was complex to say the least. He went to a scrappers and stripped one down to see how it went back togetherLike a silly person I stripped down a Rover K series VVC head, now I can't find good instructions on how to put it back together to get the cams to line up properly![]()
Back in the late 70's possibly very early 80's had a Ford Cortina MK3 1600 GT 2 door, 1972 (I think) rare even back then, hens teeth I would imagine today. But it failed MOT on the front top arm wishbone bushes, it's a bolt 15-18 inch long that goes from one side to the other through a tube obviously no grease points in it. It had seized, we ended up with 2 blow torches & a sledge hammer to try to get it out, not a F'ing chance, we ended up bending the subframe. Had to go to the scrapyard & get a full front subframe & suspension of of one in there to get it through the test. This was a car that was less than 10 years old, young uns of today don't know they're born with cars these days.
It's hardly cutting edge mechanical genius, but after finally clearing all the spares out of the back of the Lada, I got the rear seats back up. Noticed the steering wheel was a bit loose, too, plus the passenger and driver seats, so tightened them up.
Gasless....not that I've actually done that much but I've had a go with gasless.Remember you weld similar to arc/stick and drag the weld the opposite of gas mig which you push.Volvo again. Adjusted the detent plate which will hopefully assist with the 1st and reverse gear selection. Also fitted a gear knob which is nice.
In other news, no way I'm going to get the gearbox fill plug out. When the current crisis has calmed I'll take it to my local and see if they can do it on the ramps.
Also broke out the MIG welder to have a bit of practice. It's been 20+ years since I last welded, and I've never used gasless MIG before. I think I need more practice...
Capri, I had a new parcel shelf delivered, pattern part of course, so started removing the fittings from the destroyed original.
