Finished work yesterday afternoon & didn't feel like the ride I was going to do, so decided I'd put off not building the VVC (Variable Valve Camshaft) cylinder head long enough, so out into the garage to have a go, spent ages trying to get it to put one end together only to find I was trying the wrong end
then had enough walked away & then came back to it this morning.
So you start with
Then you have to build it up to
Then you have to try to fit it onto this shaft & keeping the variable cogs in line
Then eventually when you have it built up it looks like
However then you have to do it all again at the other end, but this time keeping the timing fixed so that when it's put together both ends work together. Took about 6 hours in the end
