Jobs done on the Beetle in the last couple of weeks, rocker covers off & new gaskets fitted, engine oil drained, oil filter cleaned & returned, new oil filled up. Was going to change the brake pipes but on proper inspection they had been under sealed so don't need doing. But noticed a leak from the trans-axle to driveshaft, new boot ordered & fitted, went to top the gearbox oil up only to find the container that said it was gear oil didn't have gear oil in, you can tell just by the smell. Whilst out on my ride yesterday I called in a motorspares & picked a litre up, today topped the gearbox up it was down about 1/2 litre.
Today was the horn, it was on a on/off switch in the dashboard not on the steering wheel, effectively works for regulation purposes but not if needed in an emergency. Traced the wiring that somebody had butchered, they changed the polarity around so it was positive through switch to horn to earth, this was on all new wiring just thrown into the car, there was also a relay that was there that was not doing anything, but had picked up the old wiring. Removed the steering wheel to find the wire coming up the column not connected to anything but with 12V on it so it could easily have been arcing out as we went around corners lol. Picked up the old wiring again, rewired it through the horn, then took apart the horn push in the steering wheel, modified it so it worked again, put a connector behind the horn push so the steering wheel can still be taken off, switch ignition on press horn, parp, parp parp all works as intended.
Went to start to move it, nothing, narda, no starter motor, so that looks like tomorrows job to see what I have disturbed fixing the lat few, I've either disturbed a wire in the fusebox or possibly the drive boot I put on is quite close to the starter motor so maybe I've caught something there. At least I won;t have to attach a computer to tell me what I need to replace.
