California wild fires
Beebo
Firm and Fruity
Hexleybeef
Timber housing is a massive issue in the suburbs. Like this picture.
A fire wouldn’t spread like this through an entire estate in the UK as virtually every house is brick. We learned this in 1666 after the fire of London.
I wonder if the building codes will be changed.
Half of Grand Design homes are timber (the rest are lovely concrete. mmmmm ...) Does the UK control where you build with timber?
gbb
Peterborough
It reminds me of flying back from Portugal some years ago. As I idly looked out the window on the landscape below I could see a thin, erratic bright orange line threaded across the.landscape.
Wild fire I assumed. Looked quite odd from way up.
There are some videos of people in their houses looking out on the inferno outside. I'm tempted to think these may be AI, surely the heat would burst the windows, torch the house...it just doesn't look right.
Beebo
Firm and Fruity
Hexleybeef
I dont know.
but we don’t currently have a risk of wild fires in populated areas.
I’m always amazed that they have known tornado regions in USA with light weight timber framed buildings.
Sixmile
N Ireland
My house is in a flood risk area and we've been flooded before (2008). Today it's still difficult to get flood cover because of the '1 in 25 year event' - although the house was built circa 1920 and has never previously flooded. The excess though is shocking so even if those in California could get some sort of fire cover, I'm sure the excess would've been eye watering in all cases - that is if American insurance works in anyway similar to the UK.
si_c
Wirral
Large numbers of insurance companies are pulling out of the southern california market and not renewing policies when they expire precisely due to the increased risk of wildfires. Whilst some will have reinsured through the state run insurance of last resort I'm guessing a lot of people will have let their insurance lapse.
Psamathe
I can understand the challenge. I've always considered insurance a form of spreading the risk (with an overhead for corporate profits). When high risk results in high claims so everybody has to put more in (through premiums) - the money to pay the claims has to come from somewhere with the insurance cover model society uses.
When premiums go up to cover the high claims from high risk some can no longer afford cover ...
So companies decide if it's a viable market for them to operate in or if they can make more money being more geographically constrained.
It's not unique to US, we've seen similar in UK with some insurance companies only providing cover for restricted eg properties.
But I suspect further discussion of this aspect would be into NACP section stuff.
Ian
presta
Insurance only works when there's a sufficient element of unpredictability, if you know something's going to happen, or very likely to happen, it's not insurable because the premium becomes as large as the loss you're trying to protect yourself from. If you try to pool risk with other policyholders who aren't in the same high risk category they'll just get fed up with subsidising the high risk customers and look for insurers that reject them.
Sixmile
N Ireland
The efforts to fight the fires were commendable (apart from the guy pouring oat milk on his roof) but you've got to think that the firefighters stood no chance facing the combinations of factors that they faced.
Beebo
Firm and Fruity
Hexleybeef
The logistics for where all these displaced people are going to live will be enormous.
There is only so many options available and it will take years to rebuild these homes.
And then they will need access to schools and other services.
And that one picture is probably $10-15million dollars of damage. Multiply that over the city and it will see insurance companies failing. Lloyds could be in trouble if they have reinsured some of these companies.
Gillstay
It's eminently doable, but extremely labour intensive and thus very, very expensive.
The number one thing we can do is reduce the tinder and fuel available for fires to get started or continue to burn. Reduction can be accomplished by:
  • Clearing the forest floor from brush, shrubs, and fallen trees.
    This reduces the fuel available to the fire and decreases the intensity, making it easier to fight.
  • Increasing the height of the canopy.
    The process of eliminating smaller trees that will ignite and act as an elevator to the large canopy will help prevent larger trees from igniting.
  • Eliminating smaller trees and branches.
    These are fuels that can carry a ground fire all the way from the forest floor to the top of the trees.
  • Systematically removing large trees.
    This reduces overlap of branches and the ability to transfer fire from tree to tree. Thinning can be conducted in an eco-friendly way that still maintains clusters of trees and is favorable to wildlife and habitats.
Clearing underbrush from the forest floor, thinning small trees, and maintaining large trees to prevent the spread of fire to the canopy is a sizeable project - in which you'll need mechanical assistance
So perhaps the permatanned loon was on to something, albeit a very expensive something. That said, probably a lot less expensive than the damage caused in this conflagration. When weighed against the cost of rebuilding it has turned out to be sage advice - far more than mere vague opinion.
No, because you cannot do it when you have very high temperatures so cannot do controlled burns, or your in a built up area which is where they are. Trump is neither forestry or fire trained. Hence his is only an opinion and who to say he said it anyway.
