Bump caps - do you know them?!
oxred81
Hi
Do any of you wear bump caps instead of helmets? they're basically protective caps, I think originally used on building sites.
my boyfriend is keen on wearing one instead of a helmet. I know they're not going to provide as much protection as a helmet, but are they any use at all?!
Any thoughts/experience?
thanks!
Brommie77
Crewe
Bump caps are designed to their name - eg stop a bump when you are underneath equipment / machinery that could injure you, and they are desgined to give protection from a gentle bump. Used for cycling I can't see they would be any use at all, in fact I suspect in the event of a fall it would just fly off.
I have worn them in the past when appropriate for my job, but personally there is no way I'd use one for cycling.
Lets NOT get into another helmet debate ..... :whistle:
ianrauk
Tattooed Beat Messiah
Rides Ti2
At the end of the day, it's your boyfriends choice, so let him make his own mind up.
If a bump cap works for him then that's fine.
JiMBR
Glasgow
We have them at work...I wouldn't have thought they were suitable for cycling, but as Ian says...it's up to the rider in question.
Matthames
East Sussex
I would say they would be about as much use as a chocolate tea pot and would more than likely fly off in the event of an accident. Cycle helmets are designed specifically to absorb energy over a large that would normally be experienced with an average size adult falling off head first at an average speed. Cycle helmets also have straps so that in the event of an accident they stay in place.
Hard hats are designed to absorb energy in a totally different way, like a point blow caused by somebody accidentally dropping a hammer from the top of some scaffold.
In order of protection:
Hard hats - falling objects (may have chinstrap)
bump caps - trying to stand up in spaces too small eg. under pipes, tables, etc. (lightly padded flexible plastic baseball cap, no straps)
cycle hats - saving you from certain death when falling off a bike as strapped to your head.
O
oxred81
Alright, thanks guys. I didn't want to reignite the helmet/no helmet thing....so thanks for steering clear! but I just had no experience of this.
cheers.
thomas
the tank engine
Woking/Norwich
In Vietnam I saw a couple scooter riders with hard hats on....no chin strap. haha. I think it was enough to stop the local police fining them a few dong though :tongue:
This seems like quite a strange thing to say. It's one thing to say "if the cycle shorts work for him" or even "if the break pads work for him" but with a cycle helmet, working is what happens in the unlikely event of your head hitting the pavement. And that's not the time to find out it doesn't work for you.
A hankie with four knots tied in the corners (and a bobby pin to hold it on) works as well as a helmet ~100% of the time.
Brommie77
Crewe
Hmmmmmm :unsure:
:bicycle: cant see any emoticons with helmets, but this guy looks like hes just wearing a cap, so does that mean they are endorsed....:biggrin:
