Jameshow
800 litres of water! Wow. That will do it.
I appreciate they are trying but that’s less than 1 cubic metre of water.
I built half a dozen of them years ago, felt like a token effort tbh!
Flood management on the Today programme here on the Avon at Bristol, from 1:41:32. (8 mins)
In essence, they're saying that the solution is to blot up the water high in the catchment area so that it's released slowly, at a manageable rate, rather than in one short sharp surge.
Have a gander around Water Lane, south of the railway station. The Halifax building has had its ground floor flooded a few times in its lifetime.But when they build on the flood plane higher up in the aire valley for instance, it's no surprise that kirkstall / Leeds gets flooded.
But if your shower is above a shower tray and you put a blanket in that, you will flood your bathroom!When you switch on the shower the water runs down the plughole immediately, but if you lay a blanket in the bath it will absorb water for a long while, and then release it in a slow trickle.
Nearly all the mills were in The Valley as well. In their early days powered by water. Goods shipped in and out via the canal.But if your shower is above a shower tray and you put a blanket in that, you will flood your bathroom!
(The previous owners of this house had evidently done something like that because there was water damage to the kitchen ceiling below, and signs of arcing around the wiring of the kitchen light.)
It is very obvious round here that rainwater comes down off the moors far too quickly after storms. I read that the historic reason is that landowners were more interested in land management that allowed more pheasants to be shot on the hills than fewer peasants to be flooded out of their homes in the valley!
Planting lots of trees in the mid-high upland regions of any rivers' catchment area would help a lot, i reckon....
Yes - the problem was landowners chopping the trees down in the first place, and digging ditches to drain the moors.Planting lots of trees in the mid-high upland regions of any rivers' catchment area would help a lot, i reckon.
Baitings Dam, alongside the A58.Nobody's talking about damming a valley all the way to the top so that it overflows into a neighbouring valley, are they. It follows from the fact that forecasters warn of a higher flood risk when the ground is saturated and can't hold any more water that the flood risk is lower when the ground is absorbent. Slowing the release of water from the catchment area reduces flood risk.
But they can only hold a certain amount of water. After which any excess will just be running off.
