Cubist
Still wavin'
- Ovver 'thill
I see it from the point of view that the bikes are fitted with brakes. If the brakes are adjusted correctly, they do the intended job of stopping the bike. If the owner doesn't maintain the brakes in working order, that is not the fault of the bike, manufacturer or retailer but the fault of the owner. If you don't maintain expensive Campag brakes, they will not work as intended either.
I own an old MTB which falls into this category and it has plastic cantilever brakes. They work perfectly well because I maintain them. If I didn't, they probably wouldn't work but that is true of most things in life.
Reread it and then read the bit where I said "it compounds the issue".
Go and buy as many of these piles of shite as you want. Maintain them to your heart's content, but for goodness sake don't recommend them to the inexperienced as fit for purpose! They simply aren't.
You can call them what you will, I reserve the right to scorn them as the piles of scrap they are. That is my opinion. It isn't snobbery, it a deep seated hatred of anything that doesn't do what it's supposed to do despite an appearance that it should.
