rogerzilla
I removed the clip on mine! Slows down folding. No Bromptons had them until the late noughties.
Sorry, no pic on the computer where I currently am. The "eye" goes at middle of the bolt of the seatpost-clamp (analogue to where the Brompton thingy sits). The other end clamps to the rear-frame between the ears that hold the roller wheels from above. To loosen the clamp you have to either push the bike into the damping or to unclamp it against the tension of the springloaded thingy directly or a combination of both.Can't see how that clip works....got a pic of it installed?
But the weight!no need to remove the clip, just turn the rubber block slightly and that allows it to be permanently unlocked
Frame nos, 1104 to1674 . Build date Jan 89 toAug89 .... referenced from David Henshaw "Brompton bicycle" bookThanks do you know how much and where to buy
And my serial number is 1620 but cannot work out what year it is
The bike is a T3 MK3 as far as can be told from the pics and year 2000 may fit well. Just that you may have misread the serial or frame numberThat’s actually a T6 (touring spec, 6 speed) lovely condition.
Serial numbers only are on Bromptons since late 2001/early 2002 via a sticker on the seat post tube and they do have way more digits, so this cannot be a serial. It could be a frame number (sitting on the top of the rear folding hinge, sometimes hard to read on a bike of that age) and for this bike it does not fit asAnd my serial number is 1620 but cannot work out what year it is
It isn't.If it’s a T3 @berlinonaut why is there a second gear shifter on the bars?
Same same but different, as people say in Thailand.It’s the same as mine then, mine started life off as a 2001 T3.
