Jody
Stubborn git
and changing pads also more of a PITA.
No more than 2 minutes at the most. It's way easier than installing/re-adjusting brake blocks
Rim brake: glance at pad, if wear indicators show needed, slide out old and slide in new.
Disc: get torch, peer at pads, guess if replacement needed. Take wheel off. Take pads out. Inspect. Replace if you think needed. Replace wheel.
Not by choice, but a Vauxall Corsa was pretty effective in stopping me.
The kicker though, is what’s actually available. You’ll struggle to get a nice road bike without hydro discs (and probably Di2 as well…). You definitely won’t get a decent rim braked MTB at all unless 2nd hand. All this adds cost; the ubiquity of hydro discs has IME put a significant cost barrier to getting into cycling.
Not sure I agree with this. Kind of depends on what you mean by "nice" road bike. But if you are getting into cycling and cost is an issue there are plenty of rim braked road bikes at the cheaper/entry level end of the market - I just took a peek at the Decathlon website to check and this is true.
However I know nothing about MTBs so no comment on that bit.
