Good morning,
It is interesting reading this as I moved away from the area where I was registered with a GP when I was 15, I am now 58 , so have not had an MOT call up.
I did consider registering with a GP to get one but then I considered it a bit and asked myself what is the point?
Given that the NHS has clear resource restrictions taking this test would divert resources that could be used elsewhere, but it would be an effective use of resources if it detected an issue which was fixed at a lower cost because of early detection.
Against this it is unlikely that I would listen to any advice offered that was more general, in practical terms I can't
Exercise more as I run, cycle and lift light weights,
Cut down on salt or alcohol because I already consume very little although I don't buy the current 14 units recommendation and the fact that the NHS makes such a recommendation diminishes its credibility to me.
Eat better as I already eat well.
Nor would I be willing to take tablets for the rest of my life just because a number was outside of that the system considers normal.
If I had something serious like cancer I would go the NHS, for "this is how you are" facts such as heart rate or blood pressure I have serious concerns that once you start a medicine to change this you may also start many other changes within the body that require other tablets yet does not fix the issue that you took the first tablet for.
If you asked a doctor do you recommend that I go to my local heroine dealer to get pain relief you would almost certainly get a different answer to should I take Oxycontin? Yet the "opioid crisis" was created by medical staff, was this because procedure took over and common sense got lost?
At the other end of the extreme we have a body builder told that she was fat as she had a high BMI, although we don't know how accurate this report is. :-)
https://metro.co.uk/2014/03/26/a-pi...e-must-lose-weight-and-exercise-more-4679903/
This also hits the credibility of routine tests, although I appreciate that it may be an extreme case it is staggering that anyone would not know that a body builder would weigh a lot.
So overall I came to the conclusion that the test would be a waste of NHS resources.
Bye
Ian
