nickhuds said:
hi guys, ive just orered my new boardman comp road bike from halfords
. ive taken them up on setting the bike up for me, but after reading some comments on halfords im a little concerned.
i understand from what ive read that its fairly common to recieve a bike that isnt set up properly, and in some cases fairly unsafe?
ive bought the bike from my local halfords in basildon, and to be honest the guy i spoke to upstairs in the bike section, seemed very helpfull and sounded like he new what he was talking about.
i was just wondering if anyone else has had any experiances with the basildon halfords, and also what i should be checking before riding off.
thanks for your help and advice in advance.
nick
Hi Nick,
I have seen the Boardman bikes and have to say I have been impressed by the higher end ones I have seen. I think Cycling Weekly last week gave the thumbs up to the Boardman Pro Team about £800.
I have no experience of Halfords Basildon. From my experience the level of expertise and competence they demonstrate can vary tremendously from store to store as with any large chain. The posts I have read to date most certainly support this presenting a very variable service from Halfords. Perhaps it's an issue that Halfords really need to address given that some stores are clearly doing a really good job.
My Huntingdon Halfords has a very good bike team one chap in particular I hope goes a long way in the Company. I try to give him encouragement although I feel he too gets dispirited with them. In contrast my local Peterborough Bike Hut are frankly hopeless so it is a bit of a lottery as to whether your local store is any good. I think a lot has to do with the priorities the store manager places on cycling. I don't buy much from them anyway, but the odds and sods I have, have been good and the service good.
Wrt to your current situation do you have any cycling friends who are mechanically competent to take a look at your bike? They can highlight any problems there might be so you can take it back to Halfords for them to remedy if your friend can't. I would have thought Halfords would do a free first service after a couple of weeks/months. Alternatively you could take your new bike to your LBS but they will obviously charge you and then you have all the hassle of persuading Halfords to re-imburse you if they are of a mind to. Under the Sale of Goods Act and The Supply of Goods and Services Act you would first have to take the bike back to Halfords to give them a chance to inspect, identifying the fault(s) and remedy them. Under common law they also have a duty of care to provide you with a product that is safe and will not injure you. So I would go back to them if you have any concerns with your bike. It might just be a simple case of adjustment which being a new bike may well be inevitable in some cases. It is always best to keep communications friendly but formal.
The brakes should be spot on. Test them off the bike by simply trying how effective they are by leaning on the front handlebars or the saddle for the rear brake. The lever movement should not be excessive to apply the brakes and the calipers should operate without fore and aft movement which if they do means they need tightening on their mountings. The transmission should change smoothly and not be noisy ie clicking or making rubbing sounds, the bottom bracket and chainset should have no lateral play or movement which can be tested off the bike by applying both front and rear brakes and putting pressure in each pedal to see if they is any movement in the bottom bracket or alternatively grasp each crank arm and rock laterally seeing if you can generate any movement in the bearings. If so the cups need tightening. Handle bars should be straight and tight, the wheels trued and the bike running straight. Take a test ride in their car park or get them to take a test ride with you watching. Not much else really, bikes are pretty simple. The rest is adjustment particular to you. I'm sure they will spend time with you and your bike if you go back to them with any problems and you are fairly stoic about it. It is in their interests to have a happy customer. I'm sure they would be happy to demonstrate anything for you. I wouldn't do this at peak times though as with anywhere. Bear in mind most mass produced bikes will be partially built in the factory in Taiwan and the bike shop will assemble the rest and set the bike up. They may or may not use grease on bolts and fittings. More often they don't to save on costs. As a small point I would recommend at some point in the future the whole bike is checked and all bolts fittings removed to check they have been greased prior to fitting otherwise in years to come they may be impossible to remove or shear on removal.
Oh I just read about QR above, yes check they are tight otherwise..........catastrophe. To do this from loose put the lever in the locked position and tighten the the other end deraillieur side as much as you can with your fingers, then unlock the lever on the non drive side and return to tightening the drive side one turn, then half, then quarter of a turn until it is almost impossible to fully close the lever, then back off/loosen the drive side end nut very slightly by no more than 1/4 or 1/2 a turn, so that QR lever locks firmly and tightly. Keep the wheel central in the rear frame or front forks as you do all this by holding it at the top to the stays on the rear or the top of the forks or bottom of the headset which is where you forks secure and turn on the front of the frame.
I'm sure I don't need to mention but when changing gear - only turn the pedals with mimimal power until the chain has skipped to the next sprocket (back ring) or front chain ring then re-apply full power otherwise you will quickly knacker your transmission. Much like driving a car. Your legs are your engine. Sorry if this is really basic but I see so many doing this and they wonder why their bike tansmission isn't indexing properly or is knackered. Ok it has to be set up correctly in the first place. Also once the initial lube has worn off the chain re-lube using a good one. For that you will have to look at the other threads........
You can buy cheap bike tool sets on Chainreactioncycles for £40-80.
I would highly recommend a track pump to easily keep your tyres properly inflated which will greatly reduce punctures.
Hope this has been of help.
Enjoy your bike.
Nb. Some of the responses you get when you post a thread do make you wonder about some people's shoe size but don't let that get you down, there are many on here who are constructive and genuinely want to help.
