black'n'yellow
shorter stem sounds like a reasonable option. A compact bar might be another option (unless one is already fitted?) as these also tend to have a shorter reach to the hoods and the drops...
All of my bikes feel pretty much spot on atm. Don't feel stretched out at all.
Maybe this rule of thumb you go on just so happens to work for you, but many other people not so. Just like many rules of thumb.It gives a starting point at least and can be cross checked with other quick rules, like the view of the hub rule, which coincidentally applied to me pretty well.
this suddenly came into my head while I was out riding earlier, so I stuck my elbow on the tip of the saddle (probably looked a bit weird while riding) and my fingers just about reached the steerer top cap, which means there was still another 11cm between there and the bars. Clearly this method is not for everyone - maybe it only suits dave r...![]()
Ok so tried the elbow to the saddle point exercise and it turns out i'm only about 5-10mm away from touching the rear most side of the bars!! So with all this in mind I think I might go ahead and get a 90mm stem!!!
my handle bars are supposed to be 2-4" lower than the saddle -
just tried it on my fast road tourer fingers about half way between stem and handlebar. so seams ok.
Tried it on both my road bikes and im about 20 mm shy of handlebars on both so seems to work !
Nice bike,. have the same in 56, before playing with the stem in what horizontal position is the saddle?
the 'correct one' - hopefully. Saddle height and setback is the point from which all other measurements must be established. Or you could just stick your forearm on the saddle and go from there....
