TK421
Casual Extremist
- Not at my post
Just checked the seat post and it has a 25mm set-back. I've moved the seat back 10mm from where it was. I will check its effect in the morning.
I have been doing some homework and it would seem that I have been a victim of the urban myth that I should be able to be in the saddle and touch the floor with the balls of both my feet. It's unlearning false information like that as to why I joined this amazing team.
To get the seat 4"/100mm further back then I would have to change to a much larger frame. The general consensus above is that a medium frame would be too big although I can get the same Road Sport frame in a 53cm medium for £40 at the moment which would stretch the reach 10mm and raise the base level of the seat 15mm. Both areas where it has been noted that I need to go bigger.saddle needs to be put back a lot only my view but looks about 4 inches out?
