I thought I'd documented my custom 3D printed gps mount for the Bianchi somewhere but can't find it... Anyway, I've been playing with the design a little and had a new engineering resin to try out so figured it was the perfect time to print a replacement
Here's the current design, printed in the only resin I had available at the time which happened to be light grey...
Its designed to fit a Hammerhead Karoo 2 head unit and a Bontrager Ion 200 front light. It's worked really well so I'm hoping with some tweaks the new one will continue to serve me well. I've made it slightly stiffer by extending the central rib underneath all the way to the front, then made all of the ribs thinner to make it look a little less chunky
I've also tweaked the overall silhouette, especially where it meets the underside of the bars to make it look a little more streamlined. Here is the old grey one and the new black one sat next to each other before I fitted the new one...
Similar, but different 😄 Here is the new one fitted
It looks better just for being black, but I think the outline suits the bars better too. It's all for nought really anyway as once the computer is fitted you can't see it
