cyberknight
- Land of confusion
as i work in a body shop of a manufacturer , so we have the press shop and weld shop combined its an interesting video.
1st thing comes to mind is redundancy in the event one of these presses breaks down or needs a scheduled repair as we can swap panel production between presses when needed .Then cost as the base platform design can be modified and joined with other panels from different variants to enable multi model production down the same line , panels shaped to give strength and joined to create an optimal strength /shape/weight combination , tesla might be ahead of the curve with large mould tech and i would be interested to know the properties of the cast alloy compared to a "traditional " uni body construction method.
Finally with the old style method if a quality issue arises its easier to replace a smaller panel than scrap the entire cast panel and the cost of the machinery and resources required to make the new design begs the question of cost of production .
