youngoldbloke
The range isn't *that* limited - how far are you needing to go usually?
Nope. At this point in time that would be impossible. EVs aren't routinely affordable by any stretch. If your existing vehicle has a few more years left in it, I'd stick with it. The prices will drop as uptake increases and efficiencies are found. At the moment the cheapest EVs are around £22,000. That said, a new Berlingo used to cost about £27,000 to £33,000 depending on model and before accessories and the EV appears to be priced the same. "Affordable" is thus doing a lot of heavy lifting here...
All of the box mpv EVs that I have looked up (VW e-Caddy, VW combo life EV, Peugeot e-Rifter and the eBerlingo have about the same range (circa 180 miles). Ford Torneo Connect EV is apparently coming out next year.
I was being quoted a lot less. I need a real life winter range of over 180 miles, for non-stop door to door trips. I could easily install a home charger, but my destination does not have one at the moment. Currently we make the 360 mile return trip in one day - 6+ hrs driving . Having to recharge on the journey would probably increase time so as to require us to staying overnight which would make the journey impractical.
