Yellow Saddle
- Loch side.
I'm a pretty curious guy and that is sometimes misconstrued as a challenge to a belief or statement. It wasn't. I'm interested and you seem experienced based on your posts.I'll change the post then...........I use Copaslip on my pivots and have never had a problem. Grease tends to be washed away by water sprayed onto the pivots by the brake blocks leading to corrosion on the Steel pivot pins.
Plus the bushing is in Bronze (an alloy of Copper and Tin) or Brass (an alloy of Copper and Zinc) on cheaper brakes.
Happy now?
I am still trying to understand why it is done and how it works.
Copper compounds are not designed or recommended as a rolling or sliding element (bearing) lubricant and a cantilever pivot is exactly that. It appears obvious at first why it isn't a lubricant (it has metal flakes in it), but I think the obvious masks a better reason and I'm trying to figure out why. These products, no matter who makes them, all seem to have a high film strength, which is what you want in a lubricant. The addition of metal particles would seem counter-intuitive for lubrication but then, copper is soft, the particles are small and lithium, potassium and calcium (almost metal) are all used in other lubricants albeit in chemical composition rather than native. Perhaps the copper would separate and clump?
It would hardly be a problem in a pivot with a small angular movement and I can see why you "have never had a problem."
However, if you have very successfully used copper compound in such pivots and found it better than grease, I'm interested in reasons why it works.
I don't see the bushing material being copper alloys being a reason at all. By that logic we should then use steel grease in steel bearings and nylon grease in nylon bearings.
If it is purely a question of lasting longer i.e. being more resistant to a constant spray of water and its unsuitable lubricity being good enough for the job, then so be it.
If I can add a trick to my maintenance quiver by learning something, I'll do so.
