NorvernRob
- Sheffield
^^^^you want proper butter in that, more syrup and some glacé cherries
Though possibly not if you're already overweight.
Although flapjacks are not bad they pale into insignificance when measured against the true god of cycling nibbles that is a FIG ROLL!![]()
100g brown sugar
100g low fat margerine
200g oats
2 desert spoons golden syrup
Small handful of raisins (any dried fruit will do)
A teaspoon of seeds (Lidl's)
Put margerine, sugar and syrup in non stick pan over low heat and mix until melted. Add raisins and seeds and mix in. Add oats gradually mixing in as you go. Add mixture to a greased cake tin tray. Push down with back of fork or spoon so it holds together better. Oven at 180c for 20 mins. Allow to cool before removing from tin and cutting into slices.
Butter is better than marg, and a major new study by Cambridge Uni has said unequivocally that butter is not the enemy it was once thought to be.
You don't need any fruit in, as they are tasty without. But you can add fruit, nuts, dessicated coconut, cherries, dates whatever. You can also cover with chocolate.
I wasn't suggesting you were wrong at all. I was just giving the basic recipe to others making flapjacks, who might otherwise have thought that dried fruit was a necessary component.I know you don't need fruit or extra bits but decided to just post my recipe as i do it ............. and mine has those things.![]()
I do something similar but without any sugar as I chuck in quite a lot of fruit, including mashed bananas........
Did the OP says he eats after 2 hours of riding ?
...as you need to start replacing before you run out of energy as your glycogen stores have enough for about 90 mins..
You really need to keep your fluid intake up as well, they reckon 1 bottle an hour depending on how hard your riding , how hot it is etc.I have found that eating a banana every 10 miles keep's me going as for drink I carry two water bottles on long rides and one on the short ones, but I hardly never drink from them apart from when I get a dry mouth, and then it is only a quick gargle and spit, having said this I am yet to break the 50 mile ride with only a measly 48 mile under my belt
