Yeah a 12-30 was my fallback but I'd still need a new rear mech as the short cages only seem to go up to 28T.
Currently have an Ultegra medium cage, if that'll work with a 30 then that might be worth a try.
There are at least two monster hills (for me) Hardknott and Wrynose. And its generally up and down for the 150 miles so just thought a real big bail out gear would come in handy for both steep hills and recovery on some longer shallower ones.
Some very useful tips guys, cheers.
The 28T that Shimano advise is not gospel.
Most will run a 30T because it is not the rear mech that sets the limit, it is the hanger. The longer the hanger then the more clearance you have.
Plenty of new bikes came with 30T Tiagra as standard, making Shimanos tech docs look stupid.
If in doubt go for a longer mech, the 105 long cage is very good, but most bike will run a 30t without issue. The diameter of a 30T is only just larger than a 28T. Put your gears into large large and see how much play you have in the rear mech, if you have loads, then the 30T should fit on without problems.
Yeah I suppose in simple terms if there's enough arc from small small to large large with some spare either end then nothing's under undue tension. Starting to understand the minefield now lol. Cheers :-)
I run exactly the set up you have mentioned and it's fine, with a 105 med cage. The 105 doesn't come in long cage.
My Giant Defy 4 compact has a 32T cassette.
Yep, so does my Brothers Defy 3 with Sora.
That's a good point, my Defy runs a 12-30 Tiagra which has got me up everything so far. It depends how much steep stuff you'll be climbing (ie. 10%+ )
