slowmotion
Quite dreadful
- lost somewhere
That clip was the stuff of nightmares. I'm glad you are OK, and have the confidence to get back in the saddle.
Brahan said:It may be the worst (closest) incident that you've encountered but I bet you've saved yourself from countless potentially deadly scenarios before now - which have been caused by the idiocy of the driver...a second or two later on the brakes and who knows what could have happened in any of them. (obviously I'm not suggesting you should have braked earlier here, it's 100% driver error)
It's your first time but I'm pretty sure this kind of incident is happening up and down the country daily and going unreported the majority of the time.
Spectacular in your case yes, but in the general scheme of things that cyclists have to endure the length and breadth of the country, you're very lucky that it wasn't a hell of a lot worse.
User3143 said:No you are not and it is lucky that you stayed upright because you could have been killed.
There is no excuse there at all because you are coming directly from the drivers right so there is no wing mirror/part where the windscreen and door meet blocking his/her view.
IME that tanker from the markings is a BP tanker although I may be wrong and up your neck of the words I can only presume that they run out of Grangemouth (BP have got a depot there) good luck with it and talking to the Police.
