BoldonLad
Not part of the Elite
- South Tyneside
They didn't have cyclechat to thrash these matters out over 47 page threads.
I think we need a Public Enquiry
The likes of Dixon had died out long before '76. The likes of Gene Hunt ruled the roost by then.
They were just in their final pre retirement years when I joined and I tells ya, the Phil Glennister portrayal of Hunt was mightily toned down compared to the real thing.
Yes, because it is the responsibility of all road users to be able to stop within what they can see to be clear, using their own headlights. Widespread use of rear lights encourages road users to assume that any bit of road with no red light in it is clear, which stops working abruptly when there's a sheep, tree or child in the road. Opponents of compulsory rear lights said that it would encourage some to travel too fast, crash and blame other road users for not making themselves "visible". Turned out they were correct."All thinking cyclists" oppose the principle that you must have a rear light to show your presence?
I don't see how you can be 100% certain when no evidence is available and no testing was done. Denying the possibility that more people have died as a result of "drive into any unlit space" than have been saved by "must not hit that red light" is pure Stockholm Cycling Club stuff, simply accepting the motoring lobby's word, from a time when the motoring lobby was especially zealous.I am 100% certain that rear lights (on all vehicles, not just bikes) have caused a significant reduction overall in accidents.
Yes, some will travel too fast because they expect anything in their way to have lights. But regardless of what SHOULD happen, far more will have only seen something in time because it did have lights. FAR more.
I am 100% certain because there is absolutely no way you are going to make me believe there is any possibility that people who are more visible are more likely to be hit.
Nor do I believe for one moment that any significant portion of people travel faster because they expect anything else in the road to be lit.
"More visible" is nonsense. There are no invisible road users. But that's not as important as this:I am 100% certain because there is absolutely no way you are going to make me believe there is any possibility that people who are more visible are more likely to be hit.
How else do you explain all the drivers who go faster than their ability to stop in the range of their headlights, then?Nor do I believe for one moment that any significant portion of people travel faster because they expect anything else in the road to be lit.
I am 100% certain ...
When manufacturers started to fit rear fog lamps as standard, they were usually twin units. This was linked to a type of incident collision where the following car driver assumed the car ahead was braking and took panicky avoiding action and ended up crashing. This is why fog lamps are now fitted singularly unless more than a certain distance from the light cluster.
And there is evidence that daytime light usage, particularly over bright lights, actually promotes a certain type of collision - by breaking up the riders outline the observer is deprived of the necessary visual datum required to accurately calculate velocity, and T bone type collisions in particular arise out of this.
Blindly assuming any type of light usage (or indeed any measure introduced in the name of "safety") will automatically reduce collisions or casualties is a losing proposition.
Stupidity.
Those drivers mostly wouldn't drive any differently if no vehicles had rear lights.
