Drago
- Suburban Poshshire
I still have that exact same Bladk and Decker drill.
I was gifted a Rudge Whitworth with such a panel painted out. Their grandad used it during the war for poaching, and didn’t want to be noticed :-)This is correct!
The reason I raised the white patch thing above was that perhaps it implied that mudguards were mandatory. After all if you must have a patch on your mudguards, then you must have mudguards, no?
Seemingly not. According to the book posted by @youngoldbloke above you were required to have a 12 sq in patch and "a white mudguard will meet the case" but it doesn't necessarily have to be a mudguard. If you have something else that "meets the case" (dunno what - a white square with side 3.46" would do) then you don't need to have mudguards.
In the diagram above, the other option is to have a white disc fitted instead.
Frank Colden, Camberley Wheelers, 1962, no chain guard, no mudguards:
Maybe you ran into the local verbal warning Tzar.
"All thinking cyclists" oppose the principle that you must have a rear light to show your presence?
