Daninplymouth
Metered??
Yes. It’s a nightmare really sww have the highest charges by far in the country closely followed by some of the lowest wages 🤦🏼♂️
Metered??
Interestingly they show you how much your bill means in baths/showers.
AMAZINGLY we are using 594 litres a day. Which is 7 baths or 13 showers and is normal for a household of 6.
There's just 3 of us. Unless the cat is having constant baths when I go to walk the dog. It's possible that he'd do that just to spite me.
What was happening to the surface water and did you not have the choice of installing a cistern/tank and using the runoff for other things (irrigation, toilets, whatever)?Moved into our house in May 1984 been paying the private water company that we have no choice but to use to remove our surface water, it has now come to light that they haven't been doing that until June last year, still trying to get all our money back, it's like a hot potato, we're on our 4th case worker.
It was supposed to go into the main surface water sewer down the centre of the road, but by all accounts the pipe went up the sewer then stopped the actual connection was never made so effectively a soak away, which eventually over 50 years backed all the way up our pipe up our drive.What was happening to the surface water and did you not have the choice of installing a cistern/tank and using the runoff for other things (irrigation, toilets, whatever)?
England seems very backwards in water management. Looking at the low countries across the North Sea, I understand Flemish houses now must have a storage tank of at least 5,000 litres installed when built which I think is part of the Blue Deal and I expect the Netherlands will have a similar requirement.
But British builders are not interested in the environment, all they seem to be interested in getting as many houses on the smallest plot possible, I believe in Wales there is a requirement for at least 3 solar panels on new houses, so what are the builders doing, yep only 3 panels.
And the panels are in place of tiles usually so not easy or cheap to add more. 3 panels is not going to make a dent i would think.
The number in the planning permission comes from the number in the application submitted by the builder, so they're not off the hook yet.Not sure you can entirely blame the builders for trying to get as many houses on the smallest plot possible. When we were buying a house about 3 years ago, we always had a look at the local LDP, and at any resulting planning permissions that had been granted in the area. And the planning permissions always required a minimum number of dwellings to be built.
That di rather surprise me, because I had always thought, like you, that is was the builders responsible for cramming in as many as possible.
It's possible that a development planning policy could set limits for the density, but I don't remember them being especially tight.
I've finally been 'allowed' to reduce my DD as the cap has reduced. Saved £30 a month. Still over £150 in credit though, despite taking £400 back in April.
