You jest, but we should do a TT stage in the league. Remove the chance for wheelsuckers like me from gaining that advantageIn for a penny, in for a £-do it on the TT bike![]()
You'll lose about 20-30 seconds to change bikes .... do it on a descent section and maybe even less as your avatar will continue to rollCan you not change the bike like Chris Froome? If you can just work out how long it takes to swap
Is that the new target for you speedsters on ToCDid you see Froome's 96 miler for training. Ave 28+mph, sub 4 hrs![]()
iIf i need to change bike it would probably look same when Froome need to change his bike to neutral service bike few years ago in Tour de France.
You can't change bikes unless you're stationeryYou'll lose about 20-30 seconds to change bikes .... do it on a descent section and maybe even less as your avatar will continue to roll![]()
That would be very dedicated exercise. If professional riders think that's a fastest way to finish the race then i can do that tooi
If I had a treadmill I could use that![]()
I looked up through early next week, but nothing with a 4 lap Gotham grind.Ah, that's annoying! There is a race on the Gotham Grind course tonight at 18.10, but it's only 2 laps (H & H was 4). I guess I could keep a look out for a 4 lap race on the Gotham Grind course over the next few days and try and set a time if one comes up?
good luckI get that in Zwift too. Basically the trainer is maxing out the resistance ... for me it's around 10.3W/Kg ... Which is around 830ish watts ... I guess I can find out tonight when I have my first ride in Zwift on the Neo
Just signed up for the 2 lap Gotham Grind at 6:10 too tonight. I was meant to be riding this afternoon but had to take HID to the docs and only just got back. I'll do a pootle around Zwift for 30 odd mins before the race. I may see you on the start line ... but won't see you again until the finishYou can't change bikes unless you're stationery
See you there!Just signed up for the 2 lap Gotham Grind at 6:10 too tonight. I was meant to be riding this afternoon but had to take HID to the docs and only just got back. I'll do a pootle around Zwift for 30 odd mins before the race. I may see you on the start line ... but won't see you again until the finish![]()
