mjd1988
"Download AutoHotKey (if script asks you to download legacy v1 just say yes) and create a new script with the following in it. This uses the "0" numpad key to swap to the Gravel bike, and the numpad "." key to swap back to my Tron. You will need to adjust the number of Loops based on how many times you need to press down to select your chosen bike. If you are planning on lowering the time used to come to a dead stop, you'll need to reduce the first Sleep from 5500 to one of your test."
I'll download autohotkey and play with this. I need all the help I can get
Should probably put in a disclaimer that I assume this doesn't brick your laptop!
