But it's cold outside!He is from Finland, I am speechless. Here is snow enough outside, that would be better environment for a cross-country skiing than Zwift.
Hey, that's less than I thought. Could pretty successfully 'ride' in C on genuine power.Yeah 1.5x watt multiplier!
I may drop zrtl given i will hardly ever race and sign up this instead for, hopefully, a performance boost. Though the finale is a bit daunting!
That is weird. I would have thought you're busy removing snow from your garden and whizzing about on frozen lakes!Actually here weather is changing. Instead of snowing last couple days it's been raining and melted snow fast. Little bit weird winter is been in here.
OK. That game I mentioned regarding TdZ. I just played it and decided to see if anyone else wants to.
The idea is this. Get the highest "improvement" in position that you can during a TdZ stage and report it here, ideally with a screenshot of your highest and lowest positions. It can be any stage, any length and if enough people want to play we can do a "GC" table of stages. If nobody wants to play, I win. What's not to like? If you tag me, I will collate the results.
So I started pretty much right at the back of a C ride. Logged in with about 1.5 minutes to go before the start. Starting screenshot position 718, best screenshot 109. I didn't quite make the top 100. Was fun though. A few gaps but mostly drafting through riders for 20 minutes
So Stage 1. 609 is the number to beat.
Tried this by accident on Stage 2: I forgot it was starting and was busy having a work conversation. Started 720-ish out of 748 and made it up to 200 quickly, then the double draft and groups kicked in. Finished 168th, so only 552.
Already missed one TDZ stage, likely to miss another with busy weekend, moving lad and ongoing projects to complete before Tuesday
Hi Steen. They are usually wrong when the lightning flash is green. They are corrected over time and then the flash goes blue.
Good race by the way
